Antenna MAX Duo
• Twice the Connectivity. One Seamless Enclosure. •
Integrated Dual-Modem or Dual-Router Antenna Housing
Modem Top View
MAXed Out
Synergy
Two Modems.
One Setup.
Unlimited Possibilities.
Featuring 8x 5G/LTE, 2x Wi-Fi, and GPS antenna elements, the Antenna MAX Duo delivers reliable connectivity using two modems housed in a single, ruggedized enclosure. The integrated design removes the need for external RF cabling, reducing signal loss and setup complexity.
○ Supported dual-modem Peplink router setups include:
[ BR2 Pro ]
[ 2x BR1 Pro 5G ]*
[ BR1 Mini 5G + BR1 Pro 5G ]*
*Splitter MAX is required to provide power when more than one router is used.
Using the Splitter MAX, both connectivity and power are managed through a single PoE cable, simplifying installation and reducing cable clutter.
○ Suggested cable path for dual-router setups:
MAXed Out Ruggedness
Built to endure the elements, the Antenna MAX Duo is engineered for harsh environments with a UV-stable, waterproof IP67-rated enclosure and flame-retardant, UV-resistant plastics. Compliant with MIL-STD 810F salt spray standards, it’s ready to perform reliably on land, at sea, and on the move.
MAXed Out Flexibility
Whether installed on a vessel, vehicle, or fixed location, the Antenna MAX Duo adapts to your deployment.
○ Set it up how you see fit with multiple mounting options:
Adhesive Surface Mount
Surface Mount
Pole Mount
(vertical or horizontal)
Compatible with standard 3rd party maritime VSAT dome mounts
Note: The surface mount and 3rd party maritime VSAT dome mount are NOT included in the package.
MAXed Out Savings
The Antenna MAX Duo delivers unmatched value by combining high-performance antenna arrays, robust protection, and dual-modem support into a single, compact enclosure.
It’s a space-efficient, time-saving, cost-effective, and performance-maximizing solution for maritime, mobile, enterprise, and remote deployments.
Photos
Antenna_MAX_Duo_front Antenna_MAX_Duo_persp
  • Product CodeDescription
    ANT-MAX-DUO8xLTE/5G, 2x Wi-Fi, 1xGPS 600-6000MHz, IP67, SMA male (Cellular, GPS), RP-SMA male (Wi-Fi), White
    ACW-677Surface Mount Kit for Antenna MAX Duo / Antenna MAX S
    • Antenna MAX Duo
    • L-Mount Set
    • Router fixation screws
    • 5x Rubber Support TNF-19
    • 3x Rubber Support TF-039
    • 3x RJ45 glands
    • 2x RJ45 caps
    • 1x Double-sided 3M adhesive pad
    • 1x Ethernet cable (9.84″ / 250mm)
    • 1x Ethernet cable (14.96″ / 380mm)
